219 David Brown engine
marty
03-08-2000 20:41:51
I was wondering if anybody could help me find a 219 engine for a 1212 DB.
Larry Garretson
03-09-2000 22:19:33
 Re: 219 David Brown engine in reply to marty, 03-08-2000 20:41:51
Marty
03-09-2000 20:36:01
the crank broke just in front of the center crank journal. the thrust bearing surface in the block is all chewed up. That is why I need a engine or crank and block
Elmer
03-10-2000 02:52:40
 Re: Re: 219 David Brown engine in reply to Marty, 03-09-2000 20:36:01
Somebody at some time ran it with the PTO release lever locked back.
Elmer
03-09-2000 05:07:11
what is wrong with the engine you have. The 1212 has a completely different injection pump, they put up 72 horse power. If you put a 1200 engine in you will have less horse power.
Larry Garretson
03-09-2000 22:12:56
 Re: Re: Re: 219 David Brown engine in reply to DG, 03-09-2000 19:47:33
what is wrong with these david brown engines. i have a 1410 diesel with crank broken in same place and the block on center bearing is screwed up. anyone know where i can get a crankshaft and block or complete motor for 1410 case/david brown diesel? thank you Larry Garretson Garretson2@hillsboro.net am located central Texas
Elmer
03-10-2000 02:58:06
 Re: Re: Re: Re: 219 David Brown engine in reply to Larry Garretson, 03-09-2000 22:12:56
Like i said earlier, DO NOT run engine with PTO release lever locked back for any length of time. The pressure it takes to release the PTO clutch is exerted across the thrust washers and they can't take it for any length of time. Plus if a DB crank is turned, the radius in the corner of the journal has to be ground correctly or it will break.
marty
03-12-2000 07:14:11
 Re: Re: Re: Re: Re: 219 David Brown engine in reply to Elmer, 03-10-2000 02:58:06
so it wouldn,t be safe to run this tractor using a baler, grinder or pump?
