VAC modified engine rebuild
124VAC
08-03-2009 03:54:29
If I took my 124 and bored out the sleeves as large as I safely could, (maybe 3 3/16), had custom pistons made to get my cylinder pressure up to 200 to 220 psi, bit larger valves (I think someone once told me Ford valves are a good choice for VAC head), and stuck with the stock stroke, would I hit close to 30 hp? Also, with a rebuild like this, is there any suggestions for carburation and a cam. I"m caught up and will have some time to tear into this real soon, and hoping to hear some good opinions. Thank you in advance. By the way, this is for pulling a 3mph class and dead-weight.
