Case 580B need transmision help
anthony
03-22-2000 16:26:38
#1 my tractor is stuck in 2nd geer.
#2 when the tractor gets hot it wont move.
how can I fix this problem. please help
OLIVIER
01-19-2004 13:27:11
 Re: case 580B need transmision help in reply to anthony, 03-22-2000 16:26:38
CASE 580B NEED TRANSMISION to(couple conic) ,can you help me?
Don DeTienne
01-18-2003 17:29:29
My backhoe does this same thing. I think that it is the pump that puts pressure to the clutch, if yours is stuck in 2nd gear then it is possible that your forks are bent or broke. My backhoe only has problems with the shuttle-shift part. If you have a solution for this please let me know. My backhoe when it doesn't move, makes a buzzing sound like the pump is cavitating. I changed all of my filters for the hydraulic systems and this seemed to help for a short period of time. But in no way was a complete fix. Please let me know if you have any luck
