Case 611B needs help
KL
03-26-2000 19:22:43
Case 611B gas engine is missing on one cylinder. Compression on that cylinder is lower than the other 3, but is 90lbs. We replaced the carburator and distributor. Anyone have any ide
BLR
03-27-2000 12:12:33
 Re: Case 611B needs help in reply to KL, 03-26-2000 19:22:43
With the tractor running pull the plug wire on the missing cylinder so the spark has to jump to the spark plug. If, as you increase this distance the tractor starts to run on that cylinder you have a fouled plug. If that doesn't work, check the intake and exhaust tappet clearances. When checking the clearances turn the engine through a couple of revolutions to make sure the valve train is working correctly.
