CASE VAC
GEORGE DARR
03-27-2000 13:51:42
THINKING OF PURCHASING A USED 1940'S CASE VAC IN RUNNING CONDITION. I HAVE FOUR ACS OF GROUND. AND WANT TO USE TO PLOW SNOW, MAYBE CUT GRASS, PULL LOGS, ECT. ANY PROS OR CONS OUT THERE. WOULD LIKE ANY INFO. AVAILABLE, THANKS.
Steve
04-04-2000 00:27:32
 Re: CASE VAC in reply to GEORGE DARR, 03-27-2000 13:51:42
I have a '49 VAC that I pull a 7 1/2' finish mower to do 12 acres of grass, 2-3 times a month. It also does well with a 6' bushhog, just have to take it slow because of the non-live power p.t.o. Even with only 22 horses, it pulls downed trees around, and has been great with a rear mounted grader blade! Good Luck!
Steve
m5g
03-27-2000 14:15:37
If you are looking for a 3 pt hitch setup, most of these do not come with one. This is a major draw back. Pulling wise this is a good tractor.
My 1947 cranks with hand crank. It has plenty of power for small jobs. A little light for pulling plows. Will pull two bottoms in tough soil. I don't know anything about snow plows...I don't even see snow in S Texas.
