400 case running but missing
mark
03-28-2000 08:03:36
took my injectors to case dealer and had them tested and there o.k. my question is if the pump is out of time is it possible to run on 2-cyclinders . what it doing is missing when you give it throdle.on idel it seem to run fine i took the manifold off and 1 and 3 are dry 2and 4 are wet i dont see how it can not be in time if it runs smooth on idel.can you help.thanks
Chris Vangel
03-30-2000 00:08:45
 Re: 400 case running but missing in reply to mark, 03-28-2000 08:03:36
Again, I still believe the problem is in your timing. Diesel injection is different. The only thing that should be in the intake manifold is clean air! If there is moisture, I would think pump timing is off so far that the injector is firing while the intake valve is open. Therefore the mixture actually in the cylinder is far too lean to burn. I still haven't found the exact method of setting pump timing, you still need to find an I&T manual----it will tell you the procedure.
