19?? Case Constuction King. What is this?
Mark
04-25-2000 18:21:11
I bought an old Case backhoe cheap. The model no. is 4003381. At least, that is the only number on the only plate that I can find on the machine. I know it is a Construction King because I can read that much of the old lettering. It also has Dual Range on it. I am having trouble getting the hydralics to work, too. I have good pressure to the valve control box, but very little coming out. The ball valve and adjustments all seem in good shape, but none of the controls will move anything, but it just shrieks when I try them. I think I might have tracked it down to an in-line valve just before the backhoe valve body. Also I have a bad leak at the cover on the right side of the transmission where the brake linkage goes in. I bet that is going to be a pain in the butt to fix, eh? Any info and help will certainly be appreciated, Thanks.
