Case 580BCK Backhoe
Larry Edington
05-28-2000 08:14:36
Just bought a Case 580B. The tag says 580BCK SN 8788487. What year model is this? What's the significance of the CK?
Everything works well except the brakes. How big of a job is doing brakes on this unit? Is it something a normal home shop can do or is it something best left to the pro shops?
Any estimates on what a brake job would cost?
Finally, I need to get a trailer for this rig. What does it weigh?
Thanks,
Larry E.
Paul
05-31-2000 14:08:29
 Re: Re: Case 580BCK Backhoe in reply to Dennis, 05-30-2000 18:53:53
Brakes are not bad to do. There is a brake disc and a brake shoe on each side. I had them relined by a local shop for under $100.00.You may find as I did that there is a seal leaking allowing trans fluid to drip down on the shoes. If that is the case then you must replace the seals and it is a little tricky to do without major disassembly. The parts book shows everything very well. Good luck.
