Case 195 garden tractor
Kathy
06-01-2000 21:51:18
Does anyone know where I can get parts for a Case 195 garden tractor mower deck? The tractor runs fine, but the mower is worn out. We quit using it a few years ago because we could no longer get parts from the case dealer. I would like to get a whole new deck if possible.
BLR
06-02-2000 12:37:21
 Re: Case 195 garden tractor in reply to Kathy, 06-01-2000 21:51:18
If you're looking for bearings and seals try to get the manufacturers number off the part itself. In most situations, with that number you can order the bearing or seal from any bearing supplier. If numbers are illegible measure the inside and outside diameters, and a bearing supplier can probably match something up. A Similar thing applies to drive belts, measure length and width, and a local farm supply store can probably match something up.
