Case 500-930 engine switch
CharlieJ
07-29-2000 02:09:59
Has anyone put a complete engine from a 930 standard into a 500. If so, do they just bolt right in or is there other modifing needed. Thanks.
Jason Armstrong
08-01-2000 08:54:29
 Re: Case 500-930 engine switch in reply to CharlieJ, 07-29-2000 02:09:59
charlie,
That will depend on whether you use an early 930 standard or a late 930 standard. Early 930 standards used a six speed transmissons which is exactly the same as the 500 thus the engine is the same. 900's and 900b's also used the same transmission and engine so did the 600 with no b suffix. all of these 500, 600, 900, 900b, and early 930 standard are the same exact tractor just different sheet metal. the engine you use must be from a six speed transmission not a n eight speed like the later 930 standards.
if you need more help e-mail and i can give you my phone number and ill try to help you.
Jason Armstrong (cophgnjnky@aol.com)
