Case 430 weak brakes
Gene
08-22-2000 12:25:40
I have just replaced all linings but still find that the brakes are marginal. Cleaned off any oil residue and also replaced the seals and opened the small drain holes. I am using this machine in fairly hilly terrain and find that I have to stand on the pedal and pull on the steering wheel in order to have much effect. Is this normal, or should I look further. (I suspect that the linkage from the shoe brakes to the rod may be worn).
