1952 VAC PTO
Rex
09-07-2000 10:57:05
Recently purchased bush hog for my VAC,up to this point, I had never used PTO... When I put bush hog in gear and traveled about 10 feet in heavy weeds, the PTO stopped turning... I removed back case and found a smaller slide gear and the larger gear just behind PTO shaft stripped of many teeth, I am trying to determine if I maybe had a pre-existing condition or if the unit is that weak... any ideas? also, where would be a good source for parts...
