Ken's, Case-o Matic
mEl.
09-12-2000 04:45:12
Ken, checking some back messages revealed that you had asked a question of me on forum, sorry it got away from me. The Case-o-Matic will always be rough on clutch engagement when the clutch is used at hi throttle settings, common practice was to use the throttle and brakes to slow tractor speed without interupting the power flow. make sure the tabs are in place on the spools and that the spools are turned the right way so the tabs can interact properly, the clutch spool should knock the D D lever back to disengaged when the clutch pedal is pushed. You will learn to run it to take advantage of it's versatility. Mel
