Case 731 c
ike
10-22-2000 16:10:04
I need Info on this tractor like the year it was built horse power. It has a 8 speed tran, and hyd, clutch
ike
10-25-2000 10:09:21
 Re: Re: case 731 c in reply to ike , 10-22-2000 16:17:41
need to know how to take the shift leaver out of the transmisson will part's fall down inside
farmer
10-22-2000 19:15:31
This model was built between the yrs of 1960 to 1969,mine was built in 65.The hp is just under 60,it use to pull 4-16s yrs ago,now pull3-16s alittle easier. I took off the 16.9 tires & put on 18.4s,what difference in perforance. I only put back the calcium back in that came out of the smaller tire,didn`t need to waste power pulling all the extra weight I didn`t need. good luck
