870 Agri King No Hydraulic Pump Pressure
danny
10-22-2000 18:54:31
I've been trying to help my dad fix his old 870 Agri King. There is very little hydraulic pressure to operate the lift or external cylinders. This is still true after replacing the pump. Another problem is that the powershift barely works in low range. Could these two problems be related.
Ahmed
09-03-2004 10:12:47
 Re: 870 Agri King No Hydraulic Pump Pressure in reply to danny, 10-22-2000 18:54:31
I need hydraulic pump number 1343716S4 for combine case-240 or 255
danny
10-24-2000 21:30:21
 Re: Re: Re: 870 Agri King No Hydraulic Pump Pressure in reply to twopop, 10-23-2000 19:20:39
In reply to the hyd oil pick up screen in the 870 case tractor. Where do I find it.Do I have to take something apart to locate it?
danny
08-23-2004 21:37:56
 Re: Re: Re: Re: Re: 870 Agri King No Hydraulic in reply to Marc, 11-20-2000 19:02:29
We overhauled the remote and now everything works great.
Daniel Krehling
10-09-2004 08:26:53
 Re: Re: Re: Re: Re: 870 Agri King No Hydraulic in reply to danny, 08-23-2004 21:37:56
Everything worked great for a time and then gradually got worse. At present, the lift works great when then clutch is pressed in, however, the pressure drops very low when the clutch is released (even when the shift is in neutral). Low range, high range, and reverse are intermittent at best. I pulled apart the shift valve body and everything moved freely and looked to be in good shape. We believe it to be a problem in one or more of the clutch circuits. Any ideas? We"ll split her apart in December.
