611B No Converter pressure
Al Milono
10-23-2000 07:10:11
611B runs great has 3pt lift and power steering
which work. Selectomatic and dual range.
There is a hydraulic clutch. Gears seem to engage
but it wont move...Ideas?
Thanks
Larry
10-24-2000 09:35:54
 Re: 611B No Converter pressure in reply to Al Milono, 10-23-2000 07:10:11
Make sure you have oil in the Case-O-Matic resevoir. That is located in the center of the tractor.Check filter. It might be a good idea to get a repair manual for your tractor. Then you will know what questions to ask,if you can't figure it out your self. Good luck.
