Case 930 backhoe attachment
Mike
12-17-2000 15:30:59
I have a case 930, almost finished a backhoe attachment. I want to tap into the hydraulic output, I see no problem teeing off of that, however, I need a return line also and don't see a port. Can anyone help me, I only have the operating manual.
Ken McWilliams
12-19-2000 09:21:33
 Re: Case 930 backhoe attachment in reply to Mike, 12-17-2000 15:30:59
Mike,
You may want to consider a PTO pump and separate reservoir. The GPM of the tractor pump will probably too low to get fast movement out of the backhoe. You will probably need a minimum of 20 GPM and I doubt of the tractor's pump has that much volume.
KRM
Dennis/Ohio
12-17-2000 16:22:58
I'm assuming you have a loader and need the special fitting for power beyond connection. The return would tee in between loader control return and return filter. The power beyond connection is opposite side of loader control from pressure inlet. The special fitting has o-ring on end to seal to inner casting. Hope that helps, Dennis....
