Case 930 Head Questions
Jackey
02-09-2001 20:31:42
I have a 930 Case with diesel engine that has a blown head gasket. My questions are what should I expect to encounter when replacing the head gasket? What all will have to be removed? Will the exhaust manifolds have to be removed? What do I torque the head back to? Help, Thanks, Jackey
Roger
02-09-2001 21:10:09
 Re: Case 930 Head Questions in reply to Jackey, 02-09-2001 20:31:42
Jackey, the water will need to be drained out, remove the breather tube on top of the valve covers, remove all 3 manifolds( intake, exhaust, water ), disconnect the high pressure & return lines at the injectors. If yours is an early enough model it may have the decompressor system that will need to be disconnected. Torque values (in ft/lbs) when you re-assemble are : head bolts 150, intake & exhaust manifolds 25, water manifold 15, rocker arm brackets 40, valve covers 5 any other questions let me know..... ..Roger
