530CK Follow Up
Tim Williams
03-20-2001 05:39:38
In an earlier post I asked about the actual model tractor that I have. Thanks for the replies! I have some casting numbers etc. that may help me identify this machine. It has a model 31 hoe (swing cyl mounted on the sides), a model 31 62 inch front bucket, one dash window with fuel oil temp amp gauges. It has the Eagle on the globe (steering wheel and front grill). It says power steering and Case-O-matic. Its a gas engine that has "A290" cast behind the oil filter. The engine also has what looks like a date code cast as |6|22|30|. Steering column has G1332 cast in the center. Clutch housing has G1355 cast on right side. Left side trans has G1096 cast. Head lights are in the top of the front grill. Steering wheel has 3 spokes with one being wider. Wheel bearings purchased for the 530CK were too small and I will get those numbers. Thanks in advance for helping me find out what this realy is.
Tim
