1958 Case 311
lakeshore01
02-08-2006 18:40:01
My tractor leaks hydra fluid into trans. Can anyone tell me which seals/gaskets are needed?
Joe (Wa)
02-10-2006 00:33:19
 Re: 1958 Case 311 in reply to lakeshore, 02-09-2006 19:16:47
Bill, a kit for what? You have to be a little more clear with your input to get decent advice. As far as I know there is neither a kit for the Eagle hitch piston or the drive shaft seal replacement, you just have to buy the individual parts. I don't know that Case can still provide the original parts for either but they may be available from other vendors, I just looked up the Case p/n G10422 for the drive shaft seals and it crosses to National 470064. The gaskets you will probably have to punch out yourself. The Eagle hitch piston seals are similar if the cylinder is not scored, just o-rings that can be found at a hydraulic repair shop.
The best advice I can give you at this point is find out the exact origin of the leak and buy a service manual especially If you have to split the tractor for drive shaft seal replacement.
Joe
