Case 1030, hydrolics
todd
05-05-2001 19:58:55
i just bought a case 1030, i'm not familar with it at all, it had old rusty outlets so i put two new ones on from case, they told me that the the two outlets on the left go together and the two on the right go together, makes sense i guess. the problem is it won't lift the cylinder on my disk, the three point works fine, the fluid is on full when the tractor is shut off but when its running it barely registers on the stick, can't find in my book if you check it running or off, any help would be appreciated that you
todd
05-06-2001 19:11:43
 Re: Re: case 1030, hydrolics in reply to pappy, 05-05-2001 22:16:02
thanks its works great if you hook it up right!
