Case 580B TLB. Trans slips in 3rd4th going up-hill. Any advice on possible causes?
Andy
05-25-2001 12:34:31
The backhoe has a shuttle and goes fine in 1st and 2nd, but if driving up a steep incline in 3rd, or any in 4th, it slips. I was told the trans has forward and reverse clutches, but it slips in forward and reverse so both packs would have to be equally worn I assume. Is there a way to test the pressure, could it be the pump, or converter? Any advice would be appreciated. Thank you.
Pete
05-26-2001 21:34:41
 Re: Case 580B TLB. Trans slips in 3rd4th going up-hill. Any advice on possible causes? in reply to Andy, 05-25-2001 12:34:31
Andy, 1st change your filters and fluid, and check your pick up screen for partial blockage, but that usually resulys in reduced movement in all gears...sounds like a converter problem. Pete
