Case DC magneto
Mike
05-30-2001 10:56:25
Recently I tried to bring back an old DC that was sitting fo about 8 years. After changing the coolant, cleaning the radiator, getting a new battery(all that it needed 8 years ago) it cranked over. Sounded good until it wouldnt start. It had no spark so I figured it was the magneto so I took it off and when I took it off I found that there was two little pins that fell out with it. I would like to know what these pins are and where I can get a new magneto if it is the magneto at all. I would appreciate any help.
Tom
05-30-2001 15:39:37
 Re: Case DC magneto in reply to Mike, 05-30-2001 10:56:25
I had a similar problem with the mag on my DC-4.
Had no luck finding the parts needed to repair her so I ended up putting a distributor on. Got it from Downing tractor in Downing Wi. Tractor runs better than ever. Best single thing I did.
Alton Hargrave
08-22-2004 15:10:14
 Re: Re: Re: Case DC magneto in reply to Barry Small, 05-30-2001 20:53:45
I got tired of buying dead magnetos for my Case DC. I mounted a standard cylindrical 12 volt coil on the engine and I drilled two holes in a spare magneto. Through these I ran a coil wire and the ground wire for the exterior coil. I installed a condensor from my lawn mower in the magneto case. It started on the first try. I have run it several hours cutting weeds. It runs better than it did before. The tractor had been stalling after running about 30 minutes. I generally like to keep my tractors in stock condition, but it is very difficult to get parts for the old Case magnetos.
