430 power steering cylinder removal
Vaughn Gongawar
07-11-2001 18:24:32
How do you remove the lock pin and adjusting plug from front of power steering cylinder on a 430D?
Dennis/Ohio
07-13-2001 19:39:53
 Re: Re: 430 power steering cylinder removal in reply to Gene, 07-12-2001 08:01:01
I agree, taking the grease fitting out first gives access to swing the hump in lock pin up so you and get to it. To access the piston snap ring, you put a screw driver in rear hydrualic port and work the snap ring forward into the smaller diameter groove so piston will slide out. Best wishes, Dennis.....
