Case 1530 skidsteer
todd
07-11-2001 18:55:45
i have a no idea how this skidsteer works, i'm told it has clutches and chains that drive it, my problem is that under a load the right side makes a clunking clicking sound in a rythem, i haven't had time to find a book, any help would be greatly appreciated, oh also it gets worse the more it warms up, and only clunks when going forward, thanks todd
Max
07-11-2001 20:37:17
 Re: case 1530 skidsteer in reply to todd, 07-11-2001 18:55:45
Get the book. You will also need to construct an access plate that replaces the access plates on the sides just to adjust the clutches. It has been a while since I worked on one but I do remember those clutches being a real challenge to adjust for you need to block up the machine, remove the wheels, and install the special access plates. That wisconsin was a good challenge also when it came to working on the electrics in the ignition system. Good luck and happy tinkering.
Paul Greening
03-18-2004 09:29:59
 Re: Re: case 1530 skidsteer in reply to Max, 07-11-2001 20:37:17
Looking for a service manual for the 1530 uniloader.Can you give me some more information on the special access plates. Any used parts available. Need the variable drive pully etc.
