450 case loader converter problems
Dan
08-12-2001 19:36:21
I was running my 79 case loader under a load when I noticed that engine rpm was starting to increase as if no load was on the engine. I've got 225 psi converter pressure on a year old pump and filter and had opened the converter supply line to find it appeared to be getting fluid. The drive shaft does not spin when the engine rpm increases. Does the converter nornmal goes down this quickly. I do not see any signs of of an oil leak and the converter does make a whining noise.
