Case 1390 + 74L loader
Tony
08-26-2001 22:25:20
I have an IH Case 1390 4WD and I want to add a loader to it. I found a complete IH Case loader attachment model 74L off of a 1690 tractor in a Case salvage yard. Is this an appropriate loader for my 1390? Is there ample hydraulics to run the loader? My tractor has duel hydraulic pumps. Do I need an additional hydraulic reservoir? Are there problems mounting this loader to a 4WD tractor. The loader is heavy duty and very well built. It has factory quick release pins and fittings. I welcome any advise on this project. Thanks.
Bob
03-26-2003 18:13:55
 Re: Case 1390 + 74L loader in reply to Tony, 08-26-2001 22:25:20
Did you buy the 74L loader?
If not, I'm looking for that loader on my Case/Int 1194.
Can you tell me where to find it?
Thanks
Bob 248-882-2926
dogshilo3@aol.com
Elmer
08-27-2001 04:57:26
The 1390 was usually matched to the 54L loader. I don't think the bolt pattern on the front frame will match up because the 1690 has a longer frame. You would be best to find an old Case dealer who still has the specs and see if the loader will work. Maybe Case added extra holes to the mounting kit to accomodate the 1390 and 1490. Your hydraulic capacity is the same as the 1690.
