Answer for hyd problems on 730
Ricky
08-28-2001 08:42:34
I couldn't get the hyd's to work on my 730. I called the case dealer in San Angelo, Tx. The filter is on the pressure side of the pump. The sump in the bottom of the rear end has a screen on it. That screen will get stopped up and cause you several problems. You have to pull the housing on the rear end off and and clean that screen. It is not a big job, but one that takes about 4 hrs. If anyone needs some help in doing this just email me. Thanks, Ricky
