Case 480 Brakes keep locking up.......
Fulton
09-05-2001 11:31:09
I have an early 60's Case 480 with CK loader and a 14' Case hoe off of a 530 CK mounted. Problem is that brakes keep locking up as I am moving. Makes it real difficult to do some loader work that requires some easing into tight spots. Any info would appreciated....
Max
09-05-2001 13:35:44
 Re: Case 480 Brakes keep locking up....... in reply to Fulton, 09-05-2001 11:31:09
Sounds like the brakes are partially applied due to broken spings on the brake discs. You'll need to remove the brake housing cover to inspect the springs. If you wait long enough, the brakes will glaze over and the the brakes won't lock up. Good luck.
