Case SC Carb
David
10-17-2001 17:11:48
A friend has a Case SC that needs the Main Adj Jet for the Zenith Carb, Model 161JX7. Do any of you have a source for old Zenith parts? Thanks
Baggsy
10-18-2001 19:01:39
 Re: Re: Re: Case SC Carb in reply to Deborah, 10-18-2001 15:43:13
I'd think you could just drain the fuel out down by the carburetor, fill the tank with fresh gas and run some thru the line. You might wanna clean the carb, but you might not need to. Get it to start (it might smoke for awhile) and listen close. I'd think it might even help it some. It's alot better than putting gas in a diesel!!!
Deborah
10-18-2001 15:43:17
 Re: Re: Case SC Carb in reply to Duane(Pa), 10-18-2001 07:12:46
I have a 1942 case tractor, it has a carb, and I accidently put diesel fuel in it. It now has sat over last winter spring and summer without being drained. We haven't started it since. Now it sits. What to do? Maybe I should sell it.
Bill
10-18-2001 08:30:47
wwould be interested in that carb.
