CASE 2090 shifting problems
C.W.
10-20-2001 15:35:52
The fourth gear in our 2090 went out a couple of weeks ago. All gears work, accept when you try to put the tractor in fourth gear it will not go. It is like the linkage is not allowing the tractor to shift into fourth gear. All power shifts work in gears 1 thru 3 (not fourth because fourth does not work). Any ideas on fixing problem? Maybe pull tractor apart?
Zach
10-20-2001 15:41:05
 Re: CASE 2090 shifting problems in reply to C.W., 10-20-2001 15:35:52
Does it grind when going???? does it act like it wants to go in??? if it acts like it wants to go in try adjustin the linkage its under the cab. if that don't help its inside and you will have to pull the valvebodie off and pull the shifters out of the way it will be a PAIN IN THE BUTT we pulled a 1070 one apart it was a mess well hope t his helps
Bill from up north
10-21-2001 01:25:15
 Re: Re: CASE 2090 shifting problems in reply to Zach, 10-20-2001 15:41:05
I would get someone to try shifting it while you watch the linkage from under rt side of cab. Maybe its not going to neutral right or something like a wire or stone is jamming the linkage . Hope its something easy like that -Good luck!
