Case 2590 fuel not running out of tank!
jerry
10-28-2001 13:03:14
Tractor only runs at an idle and only a few minutes. I took the fuel line loose at the pump and barely any fuel ran out. After tracing the
line I find it goes to the tank bottom through a hole in a steel plate. Question: Is there a filter inside the tank? Can I just try to run a wire through the hose into the tank to break something loose? Do I have to remove the tank? Thanks!
John M
10-29-2001 18:40:21
 Re: Re: Case 2590 fuel not running out of tank! in reply to jerry, 10-29-2001 17:58:10
Your fuel problem is still at fuel sender sock\screen, PERIOD. Perhaps even alge in tank.
