Case 311 Camshaft Information
Mike Elliott
11-02-2001 15:42:47
I just recently rebuilt my my Case 311 and I think I could have possibly put too much torque on the camshaft nut. The tractor runs fine, but the starter will not turn the engine over. I have to pull it off. After eliminating all possible problems with the starter and timing, I was questioned about the camshaft clearance. I could not find any specs on how much clearance should be between the timing gear and the Camshaft..... Can anyone help me with this. Is there a set clearance?? I know it has a locking type washer that holds the camshaft nut from loosening, but how much is enough???
Any help is desperatly appreciated. You can e-mail me at melliott@conagrapoulty.com or mikeel2@bellsouth.net..... .....
Thanks, mike
george md
11-06-2001 22:31:17
 Re: Case 311 Camshaft Information in reply to Mike Elliott, 11-02-2001 15:42:47
Mike, cam does not use lock washer , it uses lock plate , after tightening 80-90 ft lb bend lock plate up on one flat of nut. End play of cam is set by the thrust plate [cam retainer],should be .003-.007 inch. If you tighten cam nut too much you will have a two piece cam. I doubt that is your start problem , if it wre too tight [end play] it would have failed almost immediatly. george
