Can I use multigrade oil in a case dc4? tractor
JMc... Idaho
11-16-2001 07:58:59
I just bought a case dc4 tractor and it has been sitting for quite some time .can I use muligrade oil in this? I think it is overvhead valve. Thanks for your time
george md
11-19-2001 11:15:05
 Re: Can I use multigrade oil in a case dc4? tractor in reply to JMc... Idaho, 11-16-2001 07:58:59
DC case has no rear main seal,therefore the clutch is wet, there is a second drain plug for engine oil in the clutch housing.Failure to drain at oil change will cause clutch to sludge and then slip. I agree with other reply , single weight oil. If engine has any sludge, diesel service oil will clean the inside and put the trash in the pan.Bad condition, tractor does not full flow filtering.
george
