Case 1740 moves slow
rich
11-28-2001 06:13:50
Forward and reverse moves slowly unless pushing hard on steering any clutches to adjust?
Also do both sides of the machine take diesel? There are two fill caps one on each side at the rear of the skidsteer.
lula
04-29-2003 15:51:13
 Re: case 1740 moves slow in reply to rich, 11-28-2001 06:13:50
What motor will fit into a case 1740 skid steer?
What is the proper motor?
Max
11-30-2001 22:27:09
 Re: Re: case 1740 moves slow in reply to John M Max??, 11-30-2001 22:16:38
Those clutches rely on the the side plates to hold them together. Posted at the bottom of your reply.
Joe Allen
01-02-2004 15:26:44
 Re: Re: Re: Re: case 1740 moves slow in reply to Julien, 12-05-2001 21:27:30
Hi Julien,
I got the pulley from you, now my shaft in the Hyd pump broke.
Are you still selling parts.
the shaft in the gear box and the shaft in the hyd pump. If so how much? thanks Joe
