3pt problem with DB 1200
Larry Pittenger
11-29-2001 18:07:17
I am having a problem with my 3pt hitch on a DB 1200. It will raise as soon as you start the engine but it will not lower. I have followed the problem back to the control valve. I have disassembled the control valve, cleaned and worked all of the plungers and spools, and adjusted the main spool for travel, but it still will not release hyd. fluid to the return side of the control valve. Could you please help me? Thank you Larry
Francis
05-24-2006 08:26:08
 Re: 3pt problem with DB 1200 in reply to Larry Pittenger, 11-29-2001 18:07:17
I have the same problem with my David Brown 880. Did you ever receive an answer or fix your problem?
