530 CK Brake Springs
Jason from Indi
12-04-2001 09:04:44
I took the hub off the other day and sure enough the two little return springs connected to the curved brake linings were broken. I cannot seem to get the linings out to replace the springs. The bolt that both linings pivot off of won't come loose. When I try to turn it one way or the other it tightens up. Also,on the outside of the hub are the two little caps that are directly over where the retaining springs are located. Are these supposed to come out? If they do come out, how do you get them out? They look like they are pressed in kinda like you press in freeze plugs on an engine block. Any help would be greatly appreciated!!
Thanks.
