830 Comfort King 3 point problems
Scott
12-18-2001 12:56:24
I recently purchased a 1966 830 comfort king with the draft-o-matic system. I found out the the hydraulics was full of water after I brought it home. The three point will not pick up any type of load. It wiil pick up the hay fork and that is it! Once the forks are raised it does hold its position. I changed the fluid and filter and I pressure checked the pump and it meets factory standards of 1400 to 1500 psi. I need any suggestions please. Thanks
