Case 580C Backhoe Steering Problems
Bernie
12-26-2001 12:08:02
Hi,
My neighbour is experiencing steering problems with his 580C Backhoe (1975 approx). There is a lot of play in steering wheel . . . one revolution before front end will do anything. The faster you go, the worse it is. Any suggestions?
Max
12-28-2001 19:19:54
 Re: Case 580C Backhoe Steering Problems in reply to Bernie, 12-26-2001 12:08:02
To be able to better pinpoint the problem, a little more info would be nice. In addition to the previous posts, I've seen steering problems occur after a steering hose was replaced, turned out the new hose was improperly crimped. I've also seen them where the filter was plugged, starved the pump for oil. What kind of pressure is this unit running? Do the cylinders get hot? These are pretty simple hoes' to work on and figure out. Good luck.
