1030 Oil leak
Joel WA
01-27-2002 18:17:42
My father down in OR has a Case 1030 that has a pin hole leak in an oil line. He says it comes out of the block a couple inches in front of the dipstick. May go to the oil pressure guage but I don't know for sure. Where is the serial number located on this tractor. And what might the part number be? He says the line is about as big as a copper electrical wire with coating on it yet. Any help would be appreciated. As I would like to see him get this fixed soon. Thanks Joel
jlibrande
02-05-2005 14:08:34
 Re: 1030 Oil leak in reply to Joel WA, 01-27-2002 18:17:42
Your right, it is the oil pressure line. The line on a 530 Case broke at about the same spot. Pretty easy to repair with a flairing tool, or you could 'cut & plug'! Good Luck!
