311 with rear snow plow??
Garnet
02-08-2002 23:03:02
Hello again,
I have a 311 with a rear mounted 3.hitch snow plow. It hangs out fairly far at the back and lifts a considerable amount of wieght off the front wheels. I do not notice a problem on dry ground but it loses steerability in the snow. (just keeps going straight) I have a home made wieght on the front the tracter (about 50 lbs) How many wieghts will I need to get possitive steerage up front? Are tracter wieghts standard from make to make?
Can I pick up any hooked wieghts to do the job?Thanks Garnet
Ron
02-09-2002 19:00:11
 Re: 311 with rear snow plow?? in reply to Garnet, 02-08-2002 23:03:02
You need enough weight for the job you are doing. 50 lbs. is not going to do you much good. I bolted two wheel weights on the front of my 311 which puts about 200 lbs on it. Holds it down real good when I carry heavy loads of firewood on a 3 pt. hitch carrier.
