1030
RonG
02-13-2002 18:03:57
Have an opportunity t get a 1030 for next to nothing. It has been parked in a building for years. It needs some tlc (seat, paint etc...) Here is the one that concerns me - the owner (who I know) says the back wheels are locked and he says it is the brakes. Does that sound right or is it most likely a more serious problem. He says this lockup has occured from all th years of sitting. Is this a good tractr or should I steer clear? Thanks
Ron
03-01-2002 04:40:00
 Re: 1030 in reply to RonG, 02-13-2002 18:03:57
if tractor sat many years, condensation will cause brakes to lock. Remove covers and,disassemble brake jack rear end w/12ton bottle jack and chances are wheels will be free.
bob
02-14-2002 07:24:15
 Re: Re: 1030 in reply to brian, 02-13-2002 19:22:47
if it isn,t the brakes you could have a much bigger problem the oil sligger in side the gear box may have took a dump to do this you have to split tractorand probly put in a new bearing I had this happen to mine buy if buying from a friend doubt he would steer you wrong one bad thing i couldn.t get a new slinger so had to put in used one T hey made both steel and plastic at one time
