Amp Rating
Brad Wies
02-24-2002 10:12:35
Hi guy's, I have a 1942 Case VC that was running good one day just idling and then it died and would not start again, so I have seen this before where the ignition toggle switch goes bad, so I bought a new one and later looked and noticed it is rated at 15 amps, what I need to know is how many amps does my distributor ignition need? I know for a fast you should never over load a switch but I need to know if my 15 amp switch is rated high enough to work, thanks,-Brad
