2290 jelling up
Tom Bush
03-21-2002 14:13:48
I have a case 2290 it starts hard in cold weather even with the block heater plugged in, also I have had it for 5 years and every winter I have a problem with the fuel jelling. I have used chemicals in the fuel to prevent this and I also use #1 fuel in the winter. Any suggestions?
John H
03-21-2002 18:11:50
 Re: 2290 jelling up in reply to Tom Bush, 03-21-2002 14:13:48
Tom,
Are you sure you are getting no. 1? With the Winter we been having it shouldn't jell up although not sure where you are. Used to work part time at a truck stop and many times the so called blends didn't help much. When it got down to -40 around here some of truckers even used some kerosene in the fuel. As been suggested try changing your filters and make sure its no. 1 you are using.
thanks.
