Case 580 ck shuttle clutch problem
doug
03-21-2002 19:32:53
i just bought a 580 and when i tried it out, the shuttle worked fine. When i got it home, it will not even pull itself on level ground. i need to overhaul the gas engine, but would like to know before i start if the torque converter is bad or if there is a filter or sticking pressure relief somewhere. also once when i was playing around with it, it worked just fine, but then quit again. fluid level is ok. Thanks for any help you can give me on this one!
JerryA
12-18-2005 16:10:31
 Re: case 580 ck shuttle clutch problem in reply to doug, 03-21-2002 19:32:53
Doug, what have you found out about your 580B shuttle. I have one and at times it will not move at all, say around 30 degree weather. But in 45 degree weather it takes about 5 minuets before it is ready to go. I have fluid in it. Do you think it is time for a overall on the trans. Or is that just the way the 580B’s are?
