Adjusting the clutch on a late DC
Everett Thompso
04-04-2002 15:45:52
I have just purchased a hand clutch DC with live pto and the clutch is adjusted so that it will not release. I have manuals on the older DC that show how you release a spring plunger and turn the adjusting collar to get the correct clutch adjustment. Looking in the inspection hole on the left side of the tractor at the clutch does not show either a spring plunger or a collar to turn for tension against the clutch. If anyone knows how to adjust this clutch, I would appreciate some advice.
Thanks,
Everett
Klyde
04-05-2002 09:42:43
 Re: Adjusting the clutch on a late DC in reply to Everett Thompson, 04-04-2002 15:45:52
It should be inside one of the holes in the cover. Service manual says a raised boss on the pressure plate is provided to aid in locating the lock pin.
