2090 hydrallic noise
dave
04-08-2002 19:36:25
Can anyone tell my why my 2090 case squaks, growls buzzes and what not noises when you raise and or lower the hydralics. This does it at any rpms, sometimes worse than other times and some times not at all. Also the tranny was just worked on new ring and pinion, the tranny now makes a loud gear whine going up hills almost like the old DC cases are. Are these normal things. Any help would be great.
Dave
04-10-2002 19:38:11
 Re: 2090 hydrallic noise in reply to dave, 04-08-2002 19:36:25
Thanks for all the info. YEs John the light does come on but not often. In fact I noticed the light came on tonight when Iwas going in reverse at low rpms but when I sped up the rpms the light went off. Is this a common problem, can if cause a problem? I also was wandering if the whine I am hearing was that particular thing. Is it ok to run the tractor making any one of these noises?
