Case DEX fuel line
Young Restorer
05-05-2002 14:51:44
Ive got a Dex at home but i cant get the sediment bowl to fit even though it is the correct one.The problem is it screws into the bottom of the kero tank if you remove the glass bowl but you cant put it back on again because the casting is in the way.Should there be an extended pipe that comes out of the bottom of the tank out of the way of the casting for it to screw into? Thanks.
