Case SI fuel/carb problems
Mike Snyder
05-29-2002 21:06:20
My SI starts and runs great until it warms up (about 15-20 min.) at that point the carb floods, stalls, and leaks fuel. If I let it cool off I can start it and clear the fuel load and again it will run fine until it warms back up. Any ideas on how to fix this problem?
Baggsy-Wy
05-30-2002 05:16:51
 Re: Case SI fuel/carb problems in reply to Mike Snyder, 05-29-2002 21:06:20
Get ya a carb kit for it...the Tisco kits for the zenith 9667 are $27 bucks out here and worth every penny. Sounds like the float may be sticking or the float valve has crud in it. Could also be the high speed jet has worked loose. Take the carb apart down to every little part and soak in carb cleaner. Blow all the lines and orifices out good with compressed air. Poke a torch cleaner thru each one and make sure it's squeaky clean. Check your fuel strainer bulb for rust and clean it out good. Gasket and screens are available at NAPA. Fine tractor you've got there, is there any hydraulics on it? I know the SC had 'em by '54 but I've never seen a later SI...
