530 Case Torque Converter ??'s
Emil/MA
06-13-2002 04:39:29
Just purchased tractor and have been trying to troubleshoot a shifting problem. If anyone can help with the following questions it would be appreciated:
1. Manual states to use hydraulic oil, what type?
2. Is filler plug located between 4 screws on filter cover just forward of dipstick?
3. Per manual I have 60 PSI of clutch pressure (clutch is released and tranny in neutral) while in Torque Drive and 0 PSI in Direct Drive. Also have 0 PSI converter pressure both TD and DD. Any suggestions? Ref page x-26 of manual
I have not tested Oil Pump pressure nor replaced the torque filter.
There is fluid and at the proper level in Torque Converter but not sure what type.
I have Ops manual and service manual for ref. Thanks.
